Please help me. So I plug my iphone 4s into the SS25, then open Midibridge, then open animoog and under the midi tab, nothing is there. So I go back into midi-bridge and mess around with the connections. I go back into animoog and midibridge is listed under the tab. When I select it, boom, animoog crashes. What am I doing wrong?
Thanks, Steve
Works fine for me using iPod Touch 4G.
Open MidiBridge. Connect Akai SS25 Kb in → MidiBridge Out port. Under preferences disable Visual Events and enable Run in Background.
Open Animoog. Under Setup - MIDI select MidiBridge.
Should be working at this stage. If not, try closing down and then re-opening Animoog …and make sure the SS25 volume knob is turned up ![]()
