first of all i went thru this post already http://forum.moogmusic.com/viewtopic.php?f=7&t=12815
this is my setup
i have slimphatty running via usb into my computer and audio output going into my soundcard which is the kontrol s4
my midi keyboard(oxygen 49) is going into my computer via usb
but i can’t get any sound out of ableton, master output switch is on volume is up,
midi signals are showing in and out both ways.
if i put my headphones on, i can hear sp directly perfectly. if i plug my audio output directly into my monitors i can hear it perfectly
but my ableton master output meter is not moving at all.
i thought it was a sp internal control settng problem at first but now im thinking it a daw problem.
also can i ask what i should have had downloaded as soon as i opened this slim phatty?
is there some presets i should get?
and how exactly do i install them?
thank you in advanced,
p.s : I got the sp from supposedly brand new from somebody on another forum when i opened i was not delighted to find a warranty paper, two power cables and the unit, and no hard copy manual or instructions.
Have you successfully recorded audio into Live using your interface with any other source (mike, etc.)?
How do you have the Phatty audio out connected to your interface?
What input and output settings do you have on the Phatty’s audio track inside Live?
There is no hard copy manual. There should have been a CD with a PDF copy of the manual.
