I created a sync lead patch on my Moog Little Phatty Stage II and I used the modulation to sweep OSC 2 so I get that cool sound when I push the mod wheel up. What I want to do is also be able to have vibrato on the patch but I don’t have the ability to assign a second LFO on the Moog. Is there a simple way to do this via MIDI or do I need to get an external LFO module?
Do you have any of the Moogerfoogers?
I’ve got a Korg MS04 pedal which i want to try on my sub phatty.
It has an lfo with mutiple outputs.
Although i’m not sure if patching it to the Sub Phatty’s CV in will disconnect the keyboard from controlling the pitch. Does anyone know if this will work? (I’m not at home right now, so i cant test it myself)
I think it’s a go: the PITCH CV IN signal will should be added to the keyboard generated CV.
Thats great news!! I should try this ASAP!
Thanks Stiiive
