Naming presets
Maybe someone can advise me as to how to name my presets in my Slim Phatty. I follow the instructions in the manual to the letter, as it were, and while I can save my front panel edits, my Slim Phatty will not save the name I give to the edited preset. Anyone else experience the same problem? This is very inconvenient to have numerous patches with the same name!
John Di Stefano
i suggest you should do a firmware update, it helped me out after noticing this problem.
after that, the name save works completely fine.
here you can always find the latest firmware and bugfix reports:
http://www.moogmusic.com/forum/viewtopic.php?f=7&t=11359
My Slim has the older OS installed. I’ve figured out how to save patches with new names by basically following the methods described in the manual, but before hitting Store as the last step, hit the Preset button a couple of times (you’ll see the display change between the previous name and the new name). After hitting the Preset button a few times, leave it on the new name and then try to hit Store ->Overwrite->Yes. Should work.
