So I’m tryin to save some patches and can’t figure out what button to hit to save the name. I can save the patch. I can rename the patch. But the name doesn’t save. There must be a ‘save name change’ button to hit to complete the process and I can’t remember what it is.
You don’t have to save the two separately. Once you’ve created
(or edited) a given patch, you pull up edit page 6.3, scroll cursor to, “Preset Name”, and type in the desired name for the patch.
Once you’ve completed this and push edit to exit out of the patch name screen, the name is in a buffer, and is saved with the patch when you use
the “Save Preset” function, located on the same edit page.
