I am an owner of a MIDI MuRF and a MP-201. I think the premise behind the MP-201 is great. Unfortunately, at the present it behaves in a way that makes it pretty much unusable in live situations for me.
Let me say that I play guitar and sing, so my needs may be a bit different from other posters. I am more about creating and switching patches and will probably never use the single channel on/off stuff. The MP-201 probably originated from a different perspective.
Judging from this forum though, I must say I have a great impression of the responsiveness from moog (Amos), so I hope these issues will be addressed in a future update. I’d love to be able to use the MP-201 live.
In order of importance:
#1 Global Tap Tempo
As it is now, every time I change the patch the LFO that controls the tempo starts from the initial value stored in the patch. Changing patch in the middle of a song throws away the tempo I tapped in - making it impossible to change patch.
I think tap-tempo need to connect to a global variable that is used to initialize each channel with LFO SYNC set to TAP.
#2 One shot MIDI CC messages
In order to initialize the MIDI MuRF I need to be able to send MIDI CC commands when calling up a patch. This would allow me to set all parameters of the MuRF when calling up a patch, even those that not connected to a MP-201 channel. As it is now, the MP-201 cannot fully recall the MuRF settings - even if I blow all the channels at just that
This is actually pretty specific for the MIDI MuRF, because it only changes the pattern on a program change and does not do a full recall.
I would like to see an array-like list (preferably of dynamic length, but lets say 10 slots) of CC numbers and values that are sent out when a patch is recalled. It could be implemented under the ALL edit menu with the other MIDI stuff.
#3 Footswitch layout
As I said, play guitar and sing. This makes it a pain to hit foot switches correctly, as there is not always time to look down. The ones that are easiest to hit reliably is the lower row. The thing I need to do is to most often is switch patch (between verse and chorus, for example). Right now those switches are located at the hard-to-hit top row.
I would love to have a new mode, let’s call it “patch-mode”, which remapped buttons 1<->3 and 1<->4. This would improve ergonomics enormously for me. Please make this a global option. It would really make a world of difference.
Also, in the “patch-mode”, it would be great if the tap-tempo button were dedicated to just tap tempo in this mode, and sent a MIDI Start Clock every time tap-temp is pressed (a single tap would just sync the pattern). This would make it possible to start songs in a predictable way.
I think these relatively small changes would make a big change for people in my situation. For me they would change the MP-201 from a no-go to indispensable. Here’s to hoping they get implemented!
Thanks for reading
