My delay is acting up again
Backstory: I’ve had issues with my delay pedal several times now. Basically, what happens is that I get fewer and fewer repeats; settings that used to ‘runaway’ would only give a dozen repeats, then five, then one, then none. If the mix is all the way up, there would be no signal.
The pedal has been back to Moog twice. The first time they replaced all of the delay chips and touched up some solder joints. It worked fine for a time, but then started acting up again. The second time the circuit boards were replaced. Basically, they gave me a new delay pedal in my old housing. That was also fine for a while, but then it started acting up again.
I then read about the shorting problem that people were having. The issue was that three pins were coming off of the small circuit board and could ground the unit, killing the repeats. I took mine apart and snipped the pins. Everything has been fine for several months.
Until today. Once again, I’m not getting very many repeats. If I unplug the unit (power and audio cables) I can sometimes get it to start acting normally. Right now it is functioning normally, but that doesn’t mean that it’ll work normally the next time I plug it in.
I’m at my wits’ end here. This is my favorite pedal, but I can’t rely on it to work properly. What do you think I should do?
Bryan
Are the pins shorting again?
I had a dream last night about this, that because of the pin locations, and wood swelling / stomp deformation that mine did the same thing. The fix in the dream was to install an isolation pad (electrical tape) between the poles and the chassis.
Could be, but I kind of doubt it. I’ll peek inside tonight and see if that is possible.
Bryan
The pins aren’t touching the casing. While I had it open it misbehaved and then starting acting normally again. Unplugging and reinserting the input jack seemed related to the pedal working correctly, but so did pressing lightly on the circuit board. Perhaps it is a cold solder joint somewhere? Intermittent problems stink.
What do you think I should do? Send it back to Moog for a third time?
Bryan
could be another ground point, too. maybe the contact from the cable and from your hand caused something to ground out again :confused: i dont know much about electronics but i made a couple noise boxes out of cheap pedals through trial and error soldering and when they dont work if i touch a connection or sometimes just the input it fires up again… ZZAP :open_mouth: “hey! it works again”
Ive decided that the next time that mine does it im going to call Moog.
I think we should petition to find out whats wrong. Its my favorite pedal too and I woudl be devistated if it messed up a session, seeing as how all that I do is record music.
Keep me in the loop for sure whatever you find out.
Actually, the very first time it acted up on me was during a recording session. I had specifically taken it to show it off to my engineer buddy and it wouldn’t do more than a handful of distorted repeats. I’ve used it on a number of sessions since, but am getting to the point where I won’t rely on it. I thought I had figured out what was wrong, but apparently not. This is so frustrating!
Bryan
this sucks.
tell us if you fix!
Bryan, I had been following your posts before I bought my 104z. I was reserved about getting one based on the problems people were having, but I couldn’t resist. Last night the same happened to me, the repeats have gone away. Sometimes unplugging and plugging in helps it work for a bit. So I guess it is intermittent right now. I will check the grounding issue tonight. Are these pedals just expensive junk? Such a disappointment. I have only owned it for 4 months.
I don’t think they are junk, but I do think there is a design flaw that needs to be addressed/recognized/documented by Moog. Having said that, mine has been fine for the last few weeks and sounds as good as ever. It truly is my favorite pedal that I’ve owned (and I’ve owned a fair share and tried a lot more).
I’ll bet that the problem with yours is the three prongs on the smaller circuit board hitting the casing.
Bryan
Dude! Thats close to Bob’s Level! I think though that he really had one of those Borg Eyes that can solve complex puzzles by staring at them.
I did post some pictures of mine in the other delay thread.
It has been fine for the last few months, but started acting up again today. I’m getting an RMA from Moog and I’ll send it back. Intermittent problems suck.
Bryan
Kind of on topic, do you use the loop in the delay? Could that somehow be related?
Sometimes, but not all the time. The problem happens with and without the loop engaged. I shipped it back to Moog this morning. Amos has been very accommodating, so I’m sure things will turn out well.
Bryan
For all of your troubles, they might consider just giving you a new pedal? It’s not like you’ve kicked it around the stage is it?
Did you tell them that you snipped the pins? I don’t know if they’ll give you a hard time about that or not…
Based on e-mail with Amos, if the problem isn’t something obvious, then I might get a replacement delay. It might cost me a bit for a new housing, but we’ll see.
Moog gave me the go-ahead (and instructions) to snip the pins, so I don’t think it’ll be an issue.
Bryan
well I dropped my 104z and was for sure it would start acting up again. 2 gigs and countless times using with no problems! I hope yours gets fixed.
I got my delay back from Moog today. They reused my housing, but everything else is new. Knock on wood (the side panels, perhaps?), but everything seems to work as it should.
Bryan
