Muse Sustain Pedal
So I just got a Muse, Loaded it with 1.3 and seem to have a problem
I have both a Sustain Pedal and an Expression pedal plugged in, Expression assignable controller works just fine with the expression pedal, but as soon as I step on the Sustain Pedal, the Expression Light goes off and no more working expression pedal. Why ?
Is there a way to make these separate or is this always the case? Doesn’t seem like it should work this way. as they are two separate functions.
I’m going to test this later.
I have an issue with aftertouch, but the midi monitor shows that there is response on MIDI CC 64 when I press Aftertouch.
Since this is related to peda input, I wonder if we have similar issues.
I will come back to it later.
Hi Tom,
I have the same issue. Aftertough and Sustain pedal CC seems too be flipped. When I choose Sustain Pedal for a modulation (e.g. Cutoff) in the mod matrix then I can play this with the aftertough of the Muse keyboard. Whereas when I map Afterough in th mod matrix with e.g. Cutoff, nothings happens when I press in the keybed for aftertough.
Do you still have this issue? I contacted Support for send in to their repair service. My Muse is brand new from some days ago.
I had contact with Moog support and they let me do some tests.
Since this didn’t solve the problem I had to return it to my dealer for repair. There were issues with availabilty of spare parts so it took such a long time that in the end I could collect a new Muse at my dealer.
So the problem is technically not solved in my machine, but I was very happy with the solution theu offered.
