MURF VST EDITOR! WOO WOO
Awwwww yeah! I think I’ll be grabbing another one now.
http://www.moogmusic.com/products/apps/vst-murf-controller
VST MuRF Controller
MuRF_Controller is an exciting addition for any Midi MuRF owner wanting to easily control and expand its’ power and capabilities from within their DAW.
Features include:
•Full automation functionality- Use your DAW’s plugin automation tools to create fully automated parameter changes on the MIDI MuRF. Every knob and every filter is now “easily” edited from the MuRF_Controller.
•Create, recall and save presets- Quickly capture and recall any amazing sound you have created on your MIDI MuRF. Once you’ve discovered a sound, you can easily save it within your MuRF_Controller plug-in.
• Envelope Scale- Allows you to access a time multiplier for the envelope that "stretches” or “shrinks” the duration of the envelope without changing the envelope shape. Changing the envelope time scale independent from the pattern rate provides a whole new range of sonic effects!
• LFO Rate- Directly access and control the MuRF’s LFO speed
• Staccato and Triplet mode- Allows access to even more creative musical timing modes in the MIDI MuRF
Ummm, unless I’m totally missing this, they didn’t include the pattern editor or playlist :blush:
I think I can create the patterns in the standalone, then open them in the vst, but it would have been nice to have the patterns/playlist controllable via midi.
no AU version?
Ebo
Put the murf in trigger mode and create the patterns with a sequencer inside your daw
Ohhh :slight_smile:
Edit: what is trigger mode?
What? No Audio Units??!?!
Have never heard of 'trigger mode, but you’ve never needed anything extra with the Midi Murf to
sequence the faders with a DAW, just
read the fine manual for which MIDI note triggers which fader (there are a couple of modes, so it’s like 8 faders x 3 midi notes)
and set up a sequence using those notes, big fun. No VST needed if all you want is faders on/off
Matter of fact, if you have a drum machine that outputs MIDI notes, you can sequence MM faders with that.
Big fun.
It is NOT working here for me with Ableton Live on OS X 10.6.8 !
This Plug in is only working if the plug in window is open !
(with an novation Remote controller I don’t need to open the window of a plug in)
Hmmm, if I close the window, I have no midi output, no Automation … :frowning:
Did I something wrong - any help ?
best,
frank
Did you manage to download it?
It still says"the site is down for mantainance" for me…
Yes, no problem to download.
should i upload or send it via pm ? - it is 4,1 mb
fb
i think you’re trying to check out from the store. just download from here:
http://www.moogmusic.com/products/apps/vst-murf-controller#downloads-tab
So… What about those of us running RTAS plugs on ProTools LE???
David
bump
David
Bumping again. I love my MidiMuRF and would love to have it integrated in my PT work without all the headache of inserts and midi control…
Will the AU version ever come out for this?
Would love to include this in my Logic setup.
Please !! :astonished:
Yeah cant seem to geth it working in logic to, damn would be nice tough
For now you can just use the I/O insert and midi to automate…that’s how I use it and I love it…
However…an AU would make life easier…seeing that the pattern editor won’t load saved patterns for me…
