hi-
im super interested in a murf but i want it to output the dry signal out both the left and the right outputs- anyone know how i can do this?
i run through 2 guitar amps- so i need the dry signal to go thru both amps
hi-
You could use a CP-251.
Run dry signal to the four-way multiple on 251, from multiple to 105 and to mixer input #1 on 251.
Run right output of 105 to mixer input #2 on 251.
Mixer output is now dry and right output. Mixer inputs #1 and #2 have their own level knobs, #3 and #4 are fixed levels.
Run 105 left output (dry+left) to one amp and 251 mixer output (dry+right) to the other.
Haven’t tried it, but in concept it should work.
