Multimode filter
Any suggestions for an analog multimode filter with CV?
So far I’ve found:
dotcom
vermona filter/retroverb lancet - that’s my top pick at the moment
ideas?
cwejman (spel?)
Sherman Filter Bank II
oberheim SEM’s filter sounds sick. 12db/oct though, plus everything else.
Schippmann Ebbe und Flut
http://www.schippmann-music.com/ebbeundflut.html
EARS FU2
http://www.earsnyc.com/FU2.htm
I don’t even know what you just said but I’m with Unfiltered37, the SEM is a beast and you get alot for the money despite outside appearances.
The filter is sweepable LP, notch, HP and just growls, it gives you an additional analog LFO, a high quality tuning source and a good OSC set for PWM. I bought the Midi version and the module has a good Midi-CV conversion that can be used to drive FreqBox or other OSCs and it has portamento and pitchbend that tracks well.
I’ve always wanted a Two-voice with the mini-Seq and not sure I’ll ever find one that is affordable but Tom is threatening to release his 4 voice shortly. Getting back on topic, have a serious look at the SEM. If you’re hand with electronics, you can pick up a ‘drop in’, build your own power supply, a simple case and patch panel for just $599 USD.
hello ,the mutator ( mutronics ) is a filter i donot want to miss. if it is a multimode filter ,i donot no(know)
Ebbe und Flut looks amazing, but the price is a killer.
I’d prefer a standard rack or desktop/pedal, I’m not really fond of the eurorack format, once You go eurorack there is no going back :wink:
