[MTRE] Save - Editor 3.2.0b6
When saving a new patch or over an old patch, the editor changes the values of some of the controls so the saved patch doesn’t sounds like what I’ve created. Also, saving resets the LFO rate back to 4 Bars and turns off the Hard Sync.
Thanks.
We know about VCO2 ONLY and HARD SYNC changing to OFF when saving presets,
what others params do you find to be saved wrongly ? Can you specify them ?
Do you see it on Standalone ? Plugins ?
If VST, then is it possible that you saved your session using VST3, but recalled it using VST2 ?
If this is the case than forward compatibility is not supported and it’s a known issue.
