I just installed it but it didn’t ask for the main program folder, only the plugin folders and asked me which plugin formats I wanted to install.
It seems that it recognized the path where it was installed before. This is a feature ain’t it? But what if I want to change the installation path, does it mean I have to uninstall the previous version?
I’m hitting an issue with some parameters not initializing to the MTR when loading presets created with editor 3.2.0b7.
Repro steps:
1.) Open any known good preset or panel settings.
2.) Set a specific VCO LFO AMT and VCF LFO AMT.
3.) Save and reload the preset.
4.) Play some notes and, notice there is no LFO heard being applied to VCO or VCF.
5.) Adjust the value of either VCO LFO or VCF LFO AMT and notice that the LFO modifier can be heard again.
6.) The GUI is also not drawing the value of VCO LFO AMT and VCF LFO AMT correctly when the freshly saved patch loads.
On my setup, it’s crashing Cubase 8.5.2 at startup. Both with 3.2.0b6 and 3.2.0b7. I had no success rebooting and trying to reinstall the editor.
Cubase starts correctly with 3.2.0b5.
I’m using firmware 2.1.13.
The log is attached to the post. It crashes while scanning the vst3 version of the editor. If I delete it, then it crashes on the vst version. log.zip (20.4 KB)
