[MTRE] Cubase 8.5.2 crash with 3.2.0b6/7 on OSX 10.11.6
Hello,
I’m having problems with version 3.2.0 b6 and b7. Cubase 8.5.2 crashes during the startup scan on OSX 10.11.6. Version 3.2.0 b5 works fine
I tried performing a new install after deleting the software and the preferences, but I had no luck.
I then tried deleting the instrument version (both from vst and vst3 folder), because it was reported as the cause of the crash in the log. I left only the fx version and then Cubase started correctly.
Then I tried doing the opposite (leaving only the instrument version), but Cubase kept on crashing.
Thanks for the report,
Will check this out.
Update: I found an update of the eLicenser driver, after installing it Cubase doesn’t crash anymore even with the instrument version of the Minitaur Editor.
I’ll test it again tomorrow to be sure it’s solved, probably the issue was on Cubase side or something related to my setup.
Thanks for the update,
Please see if it ever happens again and let us know.
