[MTR] vst Abltn Live saving bug
Since i installed the newest version of the MTR librarian vst i am getting error messages
when saving projects containing an instance of the plugin, regardless of whether it is active or not.
saving a project would give an error message, though saving under a new name does work.
I noticed that when i wanted to replace the default template i got an error message
referring to the Minitaur Port Handler as the culprit?
error messages:
failed to save file
failed to close file
failed to overwrite undo.config
removing every instance of the plugin solves the problem, and i can reproduce it.
Thanks for reporting,
most of these case are known and we’ll check into this soon.
Should be fixed on 3.2b4/2.1.10
Will you be able to confirm ?
