Since I’m using both the new firmware and new standalone editor concurrently, I’m not sure which is behaving badly. Midi through USB to MT in this session.
VCO2 Freq: when playing in the C4-C5 range, turning the knob +1 octave results in an audible drop down an octave once crossing the magic C5 limit. I don’t remember this happening with the 2.1.1 firmware. It was so obvious I would have remembered that. In fact, I used to joke to myself that I was cheating up to C6 with it in 2.1.1.
New LFO Shapes: don’t work for me at all. Midi lights energize when selecting.
Key Trigger and Midi Sync: erratic LFO behavior when engaged. As another member mentioned, the triangle wave sounds asymmetric…probably due to retriggering erratically with mid sync on. No noticeable key trigger heard. [Edit] Key trigger heard and seen on LFO light, masked by retriggering from midi sync.
LFO Clock Divider: behaves erratically with midi sync. Incrementally clicking through the settings (4 bar, 3 bar, 2 bar, etc) does not result in incrementally faster rates (3 bar faster than both 4 Bar and 2 bar, etc).
Hard Sync and VCO2 Only: don’t work for me. Midi lights energize when selecting.
Weirdo random one off occurrence: using a control programmed for main volume (CC-7) resulted in the LFO rate changing. Could not get it to repeat.
Legato mode on Glide seems a hair sensitive, lots of un-glided notes…but could just be my sloppy playing too.
Regards,
Alan
