Thanks for the update, Gil!
No rush. Just hadn’t heard anything in awhile and was wondering how things were going. ![]()
I’m hoping that we hear something soon. Especially the editor bugs have been around for a long time now.
It’s in work, we will post a new version as soon as we have most critical bugs sorted out.
Hello.
Just installed the fw2.1.9 from 2.1.7
No problem about the installation.
But about the usb drivers, they are working perfectly on my first PC, but not at all on my second one.
Both are on W7 64bits SP1, but the 1st is a “pro edition”, and the other is “home premium”.
On the 2nd, there is always and exclamation in the device manager.
On the 1st one, I’m working with Samplitude Pro X 2 Suite, and everything is working properly.
About the fw2.1.9, I have lots of problems already detailled in this forum, and maybe some others :
No “VCO2 Only” and “Hard Sync” and “Note Sync”
The behaviour of the VCO2 and its Freq are very strange. VCO2 seems to be very very lower than the VCO1..
Impossible to get presets from hardware to editor. The procedure starts until “128/128” then the editor says that the hardware is disconnected, but it appears connected in the “setting” panel and it’s working..
Very often, with all the knobs to zero (VCOs levels included), with nothing in the audio in, there is still a signal which can be modulated with the keyboard..
Even a Midi Panic (with Glide+ Amp Sus at 0) doesn’t cut the signal..
-LFO rate doesn’t sound in the good range with LFO shapes others than the Triangle one..
no more Hardware Glide+LFO rate to change the LFO Shape
no more harware Glide+VCO2 Level to Hard sync.
the hardware is responding well to Program Changes…but not the editor. Sometimes, it’s working but I have to change the Programs very very slowly.
And ofter, the sound is cutted…
Almost each of these issues are not permanents…Sometimes it’s working…=)
For my own utilisation, 2.1.7 was working perfectly =)
If you have any questions..
Voila..
I hope it will help.
Julien
Fw2.1.9
Editor3.1.0
PC1 : CLevo i7 4800MQ@2.7ghz / 16g Ram / Win7 x64 Pro SP1
PC2 : Gigabyte BXBT 2807 Celeron N2807@1.58 Ghz / 4g Ram / Win7 x64 Home Premium SP1
Thanks for the detailed report.
Some of the issues are know, some are unclear. I will respond to you personally on email regarding these issues, let see if we can reproduce them here.
Some of the Glide code was optimized in 2.1.13,
do you still see any similar problems with the Glide button ?
