[MTR] Minitaur Firmware 2.2.0RC10 available
Following is firmware v2.2.0RC10.
Please expect a new editor version as well, coming soon.
IMPORTANT: Please do not link this version to anyone outside this forum and beta group. It is still confidential, and may cause different versions carrying the same number of 2.2.0 to co-exist online. We will release it officially the regular way.
Firmware Download:
http://www.moogconnect.net/downloads/minitaur/Minitaur_Firmware_Beta_v2.2.0RC10.zip
Editor is still 3.2.0RC4:
https://forum.moogmusic.com/viewtopic.php?f=20&t=28125
Updating the Firmware:
  1. Enter bootloader mode: Press and hold VCO1 Wave and VCO2 Wave switches, and while keeping them both pushed plug the power cord into your Minitaur unit. Keep holding the two switches and press the Release switch, then release all switches. You should see the Glide switch LED blinking slowly, which indicates that your Minitaur is now in bootloader mode.
  2. Connect your Minitaur to your computer using a USB cable. Please connect it directly and not using any hub. If Windows starts an automatic driver search, let it install the default drivers.
  3. Load the C6 sysex program and configure C6 midi ports so they point to Minitaur In/Out (“CONFIG”)
  4. Load the ‘Erase Firmware’ file provided in the firmware zip, into the C6 program (“LOAD”)
  5. Click SEND. VCO1 Wave switch LED should blink as the old firmware is being erased. Once completed, VCO1 Wave LED should go dark and Glide LED should keep on blinking slowly.
  6. Load the firmware sysex file into the C6 program and send it to the Minitaur (“SEND”). As the syx file is being transferred, you should be able to see the Midi LED blinking rapidly, and VCO2 Wave LED blinking slowly. Once the firmware update is completed, the Minitaur should reboot automatically. Your Minitaur is now updated with the new firmware.
  7. Run the Minitaur Editor and check for the firmware version by clicking on “Settings”. It should say 2.2.0. If it says anything other than 2.2.0, it means that the beta firmware has not been updated successfully, and you should repeat the process again from the first step.
  8. Restore settings to defaults by clicking on “Restore Default Global Settings” on the Editor’s Settings page.
Successfully installed. I understand further firmware versions will always say simply 2.2.0 on the Editor, unless there’s a major change
The unit keeps the CV mappings from previous version
One thing that might or not make sense, is that if you load the unit before it has warmed up, it needs recalibrating, and if you do it after the warmup, it doesn’t?
Or is it related to something else? I say it because I don’t seem to need to make calibration lately, even after doing a firmware update almost everyday, but I recall it needed calibration as soon as I made an update some years ago
All 2.2.0RCx versions show up as 2.2.0 (which is the “release” version).
Warming up time is normal for analog synthesizers, so it makes sense that it needs to warming-up to become precisely in tune.
