[MTR] 2.1.11 Glide
I saw a glide issue posted for 2.1.10, but not the newest. I’m not sure how to even describe what the problem is, but the glide behavior is very erratic. Sometime nothing even happens until I turn the knob past 12 o’clock. When in EXP mode, merely turning the knob past zero makes a really high pitched noise. It’s interesting how the oscillator’s tune can actually be pushed past it’s octave threshold. Something is definitely not right with this. Sorry for the bad explanation, but it is so messed up and random I don’t know how to explain it. :open_mouth:
Thanks for reporting.
It is indeed a bit hard to understand what you mean, maybe it’s best that you send/upload a video demonstrating this ?
Are these the same problems reported on 2.1.10 ?
I just tried this, indeed has a bug when in exponential mode.
VCO 2 fixes its pitch in the highest note, C5, while VCO1 works fine. It is quite easy to reproduce. Turn Legato off so you can undesrstand it easier
Reported, thanks.
Hello Bichuelo,
The last issue reported should be fixed in 2.1.14, will you be able to confirm ?
Thanks !
Hi Gil,
Yes, this particular issue was fixed a couple of updates ago, the exponential mode works fine in 2.1.14
Thanks for doublechecking this !
