mp201 gas pedal sending no cv messages
Hello, I have a new mp201 and everything seems ok but the pedal from heel to toe changes only from +5.00 to 4.99 volts and sometimes stays at +5 with no modification at all, I’ve tried everything from unipolar to bipolar switching and several footpedal calibrations but the problem is always there… I’m going to send it back but maybe someone knows how to fix it! Thanks
Have you looked at the range of parameter change the pedal is set to use? Maybe that’s the problem.
Lukasz
Yep, the range it’s the correct one, from 0 to 4095… When I make the footpedal calibration the upper value it’s around 3300 while the lower one it’s always 1023 and doesn’t change, maybe this is the problem… Thanks for your replies, Antonio
