Hello it is possible to make the Update with the normal DIN midi and Not with the USB ?
Thank you
I think that is not possible.
Though the manual does not go into details of how to update the OS, it does say this under ‘Appendix E - Specifications’:
Operating System:
Flash upgradeable via MIDI SysEx.
This would imply that either the ‘MIDI DIN’ or the ‘USB Type B Port (MIDI over USB)’ would work equally well. All you need is something that will send the OS update file (like MIDI OX).
Stephen
Thankyou very much ![]()
You can try, but text next to the update clearly says:
NOTE: You MUST use USB MIDI to send the update; it will not work via standard MIDI connection.
Sorry.
Ah, right… I was only reading the manual, not any later updated material.
Thanks for the clarification.
Stephen
No problem, you’re welcome! ![]()
