mp-201 question
hi -
I am just exploring this pedal, and have out 1 going to the murf rate input, and out 2 going to murf envelope. I am trying to control both independently with the pedal. in quad mode, I hit switch 1, and get the rate changed.
I then hit button 2 to change the envelope, and it jumps to the previous pedal setting…
is there a setting so the pedal wont change until it reaches it’s previous setting?
I am wrapping my head around this, one bit at a time, and am not so swift when it comes to digesting manuals, tho I try my best:) ( it’s called ADHD :slight_smile:)
thanks for your patience and support !
David
Hello,
You’re asking if there is a “pass-thru” mode for the foot pedal. Right now there is not, but I’ve added this to my list of things to add in the next firmware update. Should be a relatively simple addition to the code.
Amos
that will be great, Amos !
thanks!
David
