MP-201 (Midi clock division fpedal control question)
Hey guys,
I have been lurking around this forum a while, but this is my first post.
So I got a MP 201 a few weeks ago to run my filters in my bass pedal rig and it is pretty awesome.
Can I set the FPedal to control the perameters of specific clock divisions?
For example in midi clock sync can the FPedal be set so heel down is 1/4 note and toe down is 1/16 note? If so what are the approximate numerical values of each note quality. If not is there any chance of this being added to future firmware? (Amos?)
Something I just figured out the other day when trying to change between an LFO and FPedal sweep on my cutoff filter. I put a passive A/B box between the MP-201 and the cut off CV input on the filter. Channel one I ran the input for the expression pedal channel two the LFO. Now using the A/B box I can swtich between the two types of control of the cutoff within the same preset. I though it was kind of nifty and it keeps me from having to use two presets for one song.
I’m gonna dust off my AB pedal…awesome idea!
If you set the FPedal Mode to Rate, Clock Sync to MIDI… then adjust Heel Value and Toe Value and you should be able to sweep between clock divisions. If your clock is going while you are editing Heel and Toe Values, you should be able to set them by ear. I’m not sure the numerical correspondence.
Let me know if this works or not… I recall that it should.
-Amos
