Anyone excited about the possibilities here? Use your LPF as an easily tunable/controllable oscillator. Add tracking to your ring mods bag of tricks. Have precise/repeatable control over the phaser’s sweep. Store analog delay settings in your DAW. Store sequences for any of your CV gear. And lots more.
Exciting, but I was doing this years ago already w/ my Kenton CV-Midi Converter by automating CC data. ![]()
One thing I skipped over: this is sample accurate if your DAW is. Lots of CV channels, too, depending on your interface.
Probably a bit pricey if you have to buy an interface, but the software is only $200.
I was wondering about Volta for my Moogerfoogers:?:
This is an excellent idea. I think the possiblities of this combo are incredible. I had forgotten about MOTU’s Volta. I saw it a while back but then forgot about it. On of the advantages of MIDI is that you have many programs out there such Reaktor that can do a lot of things with MIDI. Turn that into a CV and you have an incredible combination. The flexiblity of CV and the programmable flexiblity of MIDI.
The FreqBox is supported for calibration.
http://www.motu.com/products/software/volta/calib.html
None of the other MF’s are mentioned. That doesn’t mean they can’t be controlled…
Interestingly enough the Little Phatty isn’t listed.
Mic
That’s pretty cool. I can imagine someone building a rudimentary monosynth with a FreqBox, a filter and a VCA controlled by Volta. Expensive and silly, but pretty cool..
I’ve been puzzling over that. I think that if you turned off the auto-tune mode and shorted the keyboard gate you should be able to get it to calibrate.
Bryan
