I have 3 Mother 32s in a Eurorack case powered by a Doepfer PSU3 (2A on +/- 12V and 4A on +5V).
The Mothers only use the +12V supply and according to spec. consume 3 x 230mA = 690mA. Actually on my meter it shows 605mA but I expect it depends on what’s going on in the Mothers at the time (e.g use of headphone amp).
With no other modules installed in the case, I’m finding an intermittent problem where the +12V line from the PSU3 doesn’t power up. The +12V LED on the A100 bus boards flashes indicating an overload. No other modules are installed right now, just the 3 Mothers.
The Mothers seem to present a large initial load on the PSU when it turns on. Maybe this is down to the bypass capacitors on the Mother’s power rails charging.
Anyone else having similar problems with powering 3 Mothers, or with the Doepfer PSU3?
