I’ve seen some other posts adjacent to this, but nothing where someone had this exact problem.
When I plug my Mother 32 into the power ribbon cable in my eurorack, the entire case stops powering on. The Mother 32 seems to work fine in it’s own case.
To be clear, I follow this process:
Shut down my rack
Plug the ribbon cable into the power bus and the Mother 32, the bus is keyed and the Mother 32 has a handy diagram, so I know I have the orientation correct
Turn on my rack
The result is that nothing in the entire system works. I’ve tried different cables, and different points on the bus, and it still doesn’t work.
Thankfully, removing the Mother 32 allowed everything else(including a Subharmonicon) to start working as expected.
I’ve checked that my case is rated for way more power than everything is drawing.
Hopefully, someone here will have some ideas.
