Mother 32 assignable output is too slow
Hello,
I’m struggling with the assignable output, even with clock=1, the dfam receiving this clock is playing I would say “half of the tempo” from cubase to midi M32.
You following?
If I took a clock output from GM arpegiator, to the ADV/clock of the dfam: it is the good tempo (and sure GM is being clock from cubase)
5 weeks , i’m trying to solve this…
Help
g.
Do you have the latest firmware? You can use lots of different subdivisions, they can even be changed in realtime and set your DFAM to whichever figure you want it to
Yes it is up to date
I have sent a video to moog. I let you know if there is something elesewhere
Oddly enough, I encountered this same issue last night, and was able to ‘fix’ it by tweaking the swing on the M32 (adjusting Tempo/gate length). I know, I shouldn’t have to do that, but I did, and it solved it. (Yes, on the latest M32 FW).
