I don’t yet have the breakout boxes, but thinking it would be cool to stack my 2 M32s with my RME for a total of 5 oscillators. I’m new to modular, so…any advice on what how this might work?
Todd
Todd
I would hook them up via midi, personally. That way the knobs on your RME should map to the same controls on the mothers (same midi cc) and you’d have the option to polychain, assuming the mothers can be polychained down the road. That would also save you from having to source buffered mults to send the pitch CV to both units and stay in tune.
You need the Midi Solutions Quatro box, to split the midi out of the RME to both mothers.
I didn’t even look at it from that perspective, but totally makes sense. I wouldn’t even need the vx-352 in this case, just control each of the 2 Mothers and the Voyager on the same midi channel simultaneously and patch to their respective inputs on my mixer/
Any other thoughts on a scenario where I choose to go the VX-352 route?
You COULD do this…
Set the filters on the mothers to completely open, get a y connector to connect both of their respective outputs into the filter input of the voyager. That way everything would still get processed through the (far superior) dual low pass filter on the voyager.
Awesome. Thanks! I’ll give this a try once the holidays are over and I can get some time with my gear again!
