Can someone recommend a good 19" cabinet for 2 Moogerfooger Rack Mount Kits? What do most people use?
You can build your own using 6U rack rails and an Ikea RAST bedside table. That’s what I did for my 19" rack needs, except I modified the RAST to accept 8U rails.
Nice, thanks! IKEA right down the road from me.
How many racks can you fit in that space?
Do a Google image search for Ikea Rast and you’ll see many people with this same idea. Easy to see from those photos exactly what you can fit.
Stephen
If you buy four 6U rails, you can mount the Foogers front and back with no issue. ![]()
i see that there are many good options for rack mounting my moogerfoogers in a studio setting, but does anyone have a suggestion for a portable “road worthy” case for the rack mount kit?? i know many years back(like 13) i saw rob mazurek of chicago underground/ isotope 217 fame play a show in philly with his foogers in front of him, granted i was not paying that close attention and could not afford a moogerfooger at that point in my life…but i do remember him have a few of them mounted and sitting on a stand at waist/chest height. anywho, is there some type of maybe dj case that would work?? i really dont want to put velcro my babies on a pedalboard.
http://www.guitarcenter.com/Odyssey-ATA-Flight-Zone-Case-for-Vestax-VCI300-105494066-i1474065.gc?source=4WWRWXGP&gclid=CNOBo9qU37sCFcY7MgodP1MAmQ&kwid=productads-plaid^48926158601-sku^105494066@ADL4GC-adType^PLA-device^c-adid^13625723081 Something like this could work, if you have 1-3 Foogers. Something like http://www.americanmusical.com/Item--i-ODY-FZGS4TRAK-LIST?src=Y0802G00SRCHCAPN&gclid=CI-L29CV37sCFSVgMgodDHkAKw would work for larger Fooger rigs.
hey Voltor07 thanks for your recommendations!
haven’t gotten that far yet but i did pick up the rack mount kit and finally got around to mounting my 101,102 and 105m tonight. i noticed a few things anyone care to chime in if this is normal?? first, moog includes 12 of the little black screws and nuts for filling in the holes after you remove the side wood panels of which you only need 8 so that’s 4 bonus screws and nuts correct??? then there are 4 “10-32 oval head screws with finish washers” what are these for? when its mounted to the rack? my other question is… ok i cheated and didn’t take the center fooger’s wood panels off like the directions state, but instead took one of each adjoining foogers panels off. from left to right i have the 102, 105m (in white), then 101. the 101 &102 are standard black with wood and for now i just thought it might look nice with all white in the center?? i can change this no big deal but my concern/ disappointment is that there is about an 1/8" gap between the metal housing of the side foogers and the wood sides of the center fooger. would this be closed if i had just followed instructions or is this just normal? also it doesnt clearly state in the instructions to remove all 3 fooger bottom plates, which i did do, but do you leave them wedged in there other than the center position which seems to be clearly indicated in the intructions. i think i have too many questions and need to get out more.
Eeyup, so it would seem…
Eeyup.
Sadly, that is normal. Some folks have made custom wood gap closers to alleviate this problem.
No idea on that one. Maybe someone else can help? I don’t actually rack any of my Foogers, but I have a basic understanding of how the rack kit works.
I don’t have a picture handy of the “rack” I built for my 6 foogers and CP using the MOOG rack brackets, but it’s quite simple.
Two Vertical 1x4 Pine, with four 1 x 2 pine horizontal braces. One on bottom, two on the back, one on top. I spaced the racks as I wanted to have room for patching, and then I drilled pilot holes in the wood for #10 Pan Head sheetmetal screws.
I think using regular racks for Moogers in the long run is going to annoy you to no end. They are simply too heavy to lug around. They make sense for a mixing board, or a tube amp, but not so much here…
I know that Moog equipment is expensive, but seriously, you’d really have to blow it and drop down a flight or two of stairs to hurt them, so long as the knobs are protected.
A soft case that would fit my Rack would be awesome, but I get by with a Uhaul shipping blanket wrapped over the knobs and then I fix it in place with a few lengths of rope - when I need to move it…
I had planned to have a case made for the foogertron by Cabbage Cases in Ohio - I got a quote one time, I think it was $130 or so for the “LiteFlight” case, with some foam inside. These are the light ABS cases that usually have a top that fits over the bottom and a couple of straps with nylon fastex buckles.
I might still do that, but being a bass player with heavy cabs and ridiculous tube amps, the last thing I’m going to lug around and store is another anvil case.
Anyway, my rack started out with me using some scrap lumber in my shed, to still being my rack 10 years later. I have hung it on the wall next to my spot in rehearsal room, and I had leaned it against a wall from the top of my speaker cabs, or other anvil cases…
I’d consider doing something a little different if I only used them in my home studio, but at this point I still like to be able to take them with me.
I’d be interested in any other methods of transport you all use though… If Gator or someone made a bag that fit my wood rack I’d be in heaven.
Monk
I keep all my Foogers on a desktop in two long rows, angled up in the rear so I can access the jacks and still butt them up against each other. When I transport them, I use the Moog square-ish bags that are ideal for Foogers. They have moveable padded compartment walls and I can fit perhaps 14 of the little beasts in two bags. Works pretty well for me.
Stephen
As there is not enough space in our home I always have to put my Foogers back into the cupboard after a session. I love the freedom I have when they are not rack mounted. But some day I would like to have them racked up like this:
Some of you already know that the IKEA Rast bedside table can be used as a rack. When you turn them upside down you can mount one rack mount kit in the front and one on the top. That can save space and in my situation, 6 Foogers would have their jacks in the same orientation as the CP-sized units.
Now I only have to save money for a Voyager RME and the VX-351/352, buy three Rast bedside tables and rack rails, ask my wife to sew dust covers and find a solution for transport… ![]()
Cheers, radioland
