Hello there,
i want to build myself a rack for simply screwing my foogers on the wall, however, i don’t know the actual height and length of a fooger. I also have no oppertunity to measure them too atm.
Could someone please do that for me the measure?
The Fooger rack shelf is 6U but the actual Fooger is 5U but you have to make room for the patchpoints. I don’t have the physical measurements handy.
You can also BARELY squeeze 3 of them into a 19 inch rack. They have us remove our side panels on the middle unit, so theres a gap on both sides of it.
Yeah, the fooger racks are 6 units…but you really need about 8 units of space if you want to access the patch points quickly, easily and without cursing.
If you are mounting them to wall you can just by rack “blanks” screw them into the rack blank and then screw the rack blank into the wall. You will not need to remove any side panels to fit three across the length of a rack blank.
