Any of you guys conect your Voyager to the analog delay, if so, how did you do it, i am looking into buying an analog delay and from what i can tell there is only one audio in/out on them?
any info appreciated
cheers
cheers
Well the delay has only one audio in, but it has a mix out and a delay out. The mix out gives a mix between the wet/dry signal (as crossfaded via the mix knob) and the delay out has the delay signal only out.
I use mostly the mix out, but if I wanted to route an alternate channel of delay to my mixer for processing elsewhere id use the delay out.
For example, you could run the mix out to your amp or board, but you could run your delay out to the input of a murf or a phaser and process that seperately and use your board to switch between them.
THen theres the other connectivity options offered via the cv’s. And theres an fx loop available also.
I think what he wants to know is if it is stereo. It is not. It is a mono device.
