That could just be a loose plastic housing or loose bobbin in the transformer. If it isn’t getting hot or anything else weird, it is most likely just going to be a minor nuisance.
Hey there,
My first post here =]
Got my MF104M today and the PSU shows the same behavior.. This comes from the transformer inside which might be from poor quality.. But good point is that Moog use traditional PSUs with transformers and linear regulators instead of the cheap switching supplies..
From electrical point of view this buzz has no negative effect…
I’ve had this problem only once before, with a Dunlop 18v power supply. The supply itself used to buzz. I believe it was due to poor quality. That being said, I haven’t had any issues with any my Moog power supplies whatsoever. However, all the power supplies I’ve received from Moog for all my Moogerfoogers are 9 volts @ 300mA. Give them a call.
I’m sure you mean 120V. The European supplies, actually all supplies made for countries except the Philippines and America, and possibly Canada, use 230-240V. All my supplies are 120V, 300mA.
Right you are. Thanks for the correction. What I meant was 300mA, not volts…basically just trying to relay to him that I’ve had a power supply that used to buzz by itself.
hey guys thanks for the info , I’m using the standard buzzy psu of the mf104 with it and there is no problem with it except that it is pretty annoying and its the only thing that makes noise in my studio . I also got a freqbox now which came with a us power supply so I had to either get a step down or a new psu , new psu was a better and cheaper option . On the freqbox psu it was written 120V , 400ma but I found a replacement psu which is 230V , 500ma , according to this info I found on moog music 500ma is okay :
at first I was a bit confused cause the freqbox manual says the power supply should be 300ma and the psu said 400ma , but that is sorted now with the new psu of 500ma
and my mf104 psu which came with it also says 400ma and in the manual it says u should use a psu rated for at least 400ma
so I think in the case of moogerfoogers you can go upto 500ma and you must not under power them either
Hi! I got my 101 Filter last week and i love it! But the 9dc Power cord feels a bit lose and “wobbly” is this normal or is this just my unit? I thought i post my question here since you already discussed the Power adapters.
Seems normal. I think they use different power sockets for different batches of the foogers. On my 104M the power connector fits very tight, on my 101 it is more lose, but the connector can get completely into the socket, whereas on the 104M still a bit of the metal shielding of the connector is visible after plugging in. The PSU is the same for both units. For me definetly a sign that different types of power sockets are used in both machines…
So don’t worry, looks normal…
