Moog Voyager RME - problem with modulation bus 2
My Moog Voyager RME behaves strangely, the amount control of modulation bus 2 doesn’t work properly: At values between 0 and 1 the full modulation can be heard, all values above 1 to 10 don’t provide any modulation.
The display shows the correct data: 0 at left stop and 255 at right stop.
Have I overlooked any setting on the device or is the RME defective?
Hi-
What are you calling Modulation Bus 2? There’s a Mod Wheel bus (MW) and a Pedal bus (P). The Mod 1 jack controls the Pedal bus. The Mod 2 jack can control either the Mod wheel bus and/or the Pedal bus if the source knob is set to mod 2.
Have you had the same results with different patches? If not check your Pot mappings.
