Moog Voyager Audio/filter Problem
Hi everyone
i was playing with my moog, when i noticed that i was getting sound just from one output,
i cheked the cables and everything was correct, then i used the headphone out and i was getting the same problem.
i turn all the knobs everything was working but the filter.., i was getting no change from the cutoff when the filter was set to hp/lp ,when i turn up all the resonance i heard sound from both outputs right/left, but i got a strange sound, some patches that use the hp/lp preset doesnt sound.
dont know what happened.
sorry for my english.
please help!
Check the setting of the Spacing parameter. Set it to the 12 0#clock position (= zero). Maybe one of the filters is just lowered in cutoff by this parameter, so that it filters nearly all sound.
Hey,
I already did that, no its something about the filter, i’m getting no sound from the oscillators on the right channel, and hp/lp doens’t recieve any sound for oscillators, I just can hear the resonance working its like a sweep sound.
Did you try the headphone output as well?
He says he did in the first post. Sounds like something came unplugged inside.
yes i tried the headphone output and is the same, as i said before just when i turn up all the resonance sounds in both channels, yes is osmething in the mixer - filter section. because then everything is working.
wanted to know if someone got this problem …
i just asked the people from moog service.
i’m getting crazy ! with my moog not working!
Hey djego,
I realize its been a while since the last post, but did you figure out what the problem was with your Moog?
Just last week I started getting the same issues :frowning: cant figure out for the life of me whats wrong with the circuit.
Hi everybody, i have the same problem…the left channel does not work anymore? Can you help me please?!
Hi everyone, i have the same problem. The Left channel does not work anymore in Dual LP mode. Why? Can you help me, please?
Hi
I sent it to moog service so they repaired for me. but again i’m getting the same problem… i just contacted moog service again. :frowning:
Hi Guys,
I have the same issue.
After 1 year and 1 month, the unit failed as yours.
No way to repair under warranty so I payed 460 Euros to get it back (February 2012).
Today it fails again with the same problem.
My 2 cents.
Having the same problem. Just started, with no prompting, on July 30th 2017. Voyager pretty much rock solid for years, and then this. What ended up being the solution? Was there a solution? Factory Service?
Thanks in advance for any and all info -
All of these units might have a problem which Moog addressed some time ago. There are some details here: https://forum.moogmusic.com/viewtopic.php?f=2&t=21943&start=45#p139850
