Does anyone think or know if the arp or sequencer will work to control another synth through the midi output?
The Little Phatty arpeggiator can drive other instruments through MIDI. I’m sure the Sub 37’s will too.
thanks duder!
The SUB 37 will have a global MIDI OUTPUT parameter allowing the choice of SEQ or KEYS.
thanks for that, anyone know if it will be able to play from the input and its own sounds at the same time through its output? say I route a synth into it, and then run that sub37 out and want to play both synths at the same time…
Do you mean audio or MIDI?
For MIDI there are parameters called ECHO DIN and ECHO USB.
You can choose OFF, DIN, or BOTH for either.
I am speaking of audio, sorry for not clarifying.
The FDBK/EXT IN knob in the MIXER section allows you to blend the external audio input with OSC 1, SUB OSC, SUB OSC 2, and NOISE. That mix collectively feeds the Filter and then the Amplifier.
thanks DemonDan
