I have two issues with my old Moog Prodigy v.1 with cv mod
1: Osc2 gets higher and higher in pitch the higher up you play on the keyboard. I have opened it up and turned the key scale trim pot. Osc1 is in perfect order!!!
2: sometimes , very seldom, the highest octave on The keyboard trigger a half note to high. If you press The same note again it switches to The correct. Only on The last upper octave C—>C
Something you can fix easily or leave it to a pro?
Sounds for me as if there would be a temperature problem with the transistor array U3 (3046). This IC controls the octave “spreading / inclination” of oscillator 2. Try to replace it and / or resolder the pins (might be on socket).
All your problems sound like dirty contacts. First on the J-Wires of the keyboard, and second on the connectors going to and coming from the different boards, and third possibly on the legs of some chips that are on sockets. A good cleaning of all of those seems in order, IMHO.
