Hi, my moog prodigy is having filter problems! If the cutoff is very low the sound turns static-y instead of smoothly dying out. For example if I turn the attack up a little slower it will be completely quiet and then BOOM sizzle loud static and then suddenly the note sounds normal. If the release is on, the it acts the same way when it is fading out. Is this a problem with the filter or the envelopes? I’m lost! Also I need a replacement pot or shaft. 10k linear. Does anyone know where to get these? Thanks for reading!
Greg
Send Kevin Lightner a PM. He should be able to point you in the right direction. Good luck! ![]()
