I’ve read a lot about the Opus 3 String section being notorious for failing. But what fails? Can anyone pinpoint a component or connection that is likely to fail? I see from the schematics that the Strings run to the Chorus mixer section. The 3080A chorus VCA on my unit is reading correct voltage, but I have no output from the Chorus mixer section (but I do get organ from the other two mixer sections). Thanks!
If i remember correctly, the notorious chorus failure is via the Reticon SAD512 chip, I know these were hard to come by years ago..I don’t know if anyone has remanufactured them.
mine has a broken TOS divider chip…i can’t find one so it sits in my closet in 10 pieces…it’s quite sad actually.
I tested the three SAD512’s. They’re all reading around 6-7V which seems about right. And aren’t these three parallel paths? If one SAD512 fails is it catastrophic to the chorus circuit? Or must all three fail to render it inoperable?
Something simple that is common to both Strings and Organ in the Chorus path is the Strings/Organ mix slider (10K LIN). It’s reading 0-150+K while the PAN sliders (10K LIN) read 0-3K. Seems like a 10K slider shouldn’t read over 10K…? Stop me if I’m wrong!!!
You are measuring the potentiometer while it is in the circuit. Doing so can give a different value than what it really is due to the surrounding circuitry.
Have you tried listening to the mix slider? I would use a small amp with one
end grounded and the other end to probe for audio signals first. See if
there is a signal from the string section and organ section at the mix
slider, and work down from there. I have trouble-shot many a problem just
by listening to the signals at various spots. I generaly use a small 9V amp
with a little 3" speaker. Does the job!
Terry
That’s a great troubleshooting suggestion.
My Opus had an intermittent problem with no output from the chorus section, but in my case the organ/strings mix slider was the culprit – a replacement and it was 100%. The sliders are known to be fragile, but if your problem is NOT intermittent then I would guess it’s a circuitry thing.
