Moog One Signal Path
Hi!
Has anyone encountered any good image of the signal path on Moog One. I mean with the inserts, FX and everything included. I would like to understand at what point sounds goes to the insert and when the sound is coming back via the insert what is happening.
At least I notice that it’s a shame that One can’t send left channel on insert one and right channel on insert two. So if stereo spread is enabled that will switch to mono for insert. Also the insert seems to be working like send. So if I want completely wet signal back I need to turn the volume of synth 1 down to zero. After that the internal synth FX won’t do anything of course, but I will get proper wet sound. So it seems that insert/return is happening before the FX but it doesn’t seem to go through master either.
