Can I connect the Moog Muse to my Doepfer Dark Time Sequencer?
Hi
Absolutely no reason why not if the DarkMind can put its Sequence data out on MIDI and you then set up the Moog Muse to receive that MIDI data.
Than you Derek,
I’m new to all that stuff.
No worries, we all have to start somewhere ![]()
I do not have a DeepMind, so cannot give specific advice on what to do that end. But if you are stuck, I could give you a generic example using a DAW sequencer driving the Muse and some options for check the DeepMind MIDI output (if you have a PC or MAC as well).
Thanks.
It is a Doepfer Dark Time Sequencer not Deepmind.
Thanks again
The sequencer has 2 ways to accomplish this. MIDI IN/OUT conenctions should work.
You can also connect sequencer CV1 out to the MUSE CV1 in. Check the Muse manual for proper setup of the CV and Gate requirements and system settings via the front panel menu.
Thank you so much for your help!!!
