I’ve finally finished to install the REV2 software fo the minitaur.
After watching alot of videos of Amos,just trying to understand how to use it as an instrument even in my software (protools) I’ve just realized that it might not working on protools,as this one read just RTAS stuff and AAX …
Does anyone can say to me if I’m right or maybe is it possible to use it on Protools as well?..
In protools, if you create à midi track, you can assign input and output of this midi track to the MT!..so you won’t be able to run the editor as plugin but in à standalone app, it Will still send midi infos to the MT .
The midi tracks can record midi clip infos in protools and you can record LFO, filter and other automations as well. The only problem is that for every midi controller you record, protools didn’t neccesarely assign it with the good names and you can’t change it!!..grrrr!..so basically that’s the best I did with protools 11!!..hope it helped!!.
