I’m working on a comprehensive guide on Moog MG-1 mods. I should be done in a couple weeks. Since I’m still working it all out, I thought this was interesting enough to bring up in it’s own thread.
While I have my MG-1 open I decided to see what I can do to make the synth sound better overall. You’ll see a lot of opinions regarding how the MG-1, Rogue and Prodigy sound thinner than the more desirable Moogs. Moog was trying to cut corners to make a more affordable synth. There are two odd choices with component selection that seem to make these synths sound different from the others.
Ladder Filter Cap Values
I spent some time studying every Moog schematic I could find. I found that the cap value choice in the filter section directly corresponds to how people perceive the depth of the synths. Here is a list of the capacitor values along with base resistors in multiple Moog synths:
My calculations were flawed in this. The different resistor values in the filter will also play a big role in the sweep. Calibration will also make a difference. I’m working to create a more accurate list of the different variations of the filter.
Source, Polymoog, Opus 3 - .01uF - 150 ohm
MG-1 - .027uF - 200 ohm
Prodigy, Rogue, Taurus II, Liberation - .027uF - 1k ohm
Micromoog, Multimoog - .033uF - 1k ohm
Minimoog, Sonic Six - .068uF - 150 ohm
Taurus - .1uF - 1k ohm
Low Value Caps Replaced With Resistors
There is something else that Moog did that I don’t quite understand. They used low value resistors in place of all ceramic capacitors. I’ve heard rumors of companies doing this as a cost cutting measure since resistors are cheaper, but can’t confirm. When you look at a Moog MG-1, Rogue and Prodigy pcb, you’ll notice there are quite a few bright green metal film resistors. All of these will be low value, under 800 ohms. These were put in place of most caps lower than .01uF. I had all the caps I needed on hand, so I replaced the resistors with the correct value caps. The synth became quieter, more stable and the overall quality of sound greatly improved. It seems more professional now.
So, for around $2 in parts, these “mods” brought my MG-1 into a completely different level. I hope this helps somebody out.
P.S. I haven’t measured or replaced the transistors in the ladder filter yet, but if Moog was cutting corners on the following parts, I’m pretty sure they were skipping out on transistor matching. I’ll post an update on this when I have it.
