Hello everybody,
Have a Moog Matriarch from 2020 that has the main LFO currently not working. Engaging it with mod wheel does nothing, patching wave out to mixer generates nothing, changing shapes/different option on modulation panel changes nothing. S&H works and follows the rate knob despite stuck LED, noise out works, patching to sync in and rate in does nothing, patched Mod Wheel out to attenuators and it behaves as expected. Replaced power supply, updated firmware, recalibrated pots and notes, restarted to factory settings and still the same behavior.
Something odd about this is that I had this issue about a year ago, was using the synth in a rehearsal and while messing with the sync/tap it started blinking again, used the mod wheel and it was working like nothing happened. Worked for about another 6 months and started showing the same behavior since last month.
Here’s a Reddit thread I created last year showcasing the behavior.
So yeah, just posting in case somebody has any insight on this, I work with electronics for a living and am planning to take it apart and see if I can spot something, but wanted to check in here if there’s anything I may have missed.
Appreciate any help.
