Hi - since my update of the new firmware I can’t change the Matriarch’s default MIDI channel from 1. Tried multiple times with midi cables in and out etc - just doesn’t seem to do anything using the global parameter changes. Has anybody else experienced this? Very frustrating.
Also have the issue with the “wobbly” delay sync over MIDI and also not being able to use the Matriarch’s arp/seq until I start the DAW (can’t change this in the Global settings either).
No trouble with that here, Midi channel is changed as expected. You may want to check with one of the settings editors MatriarchSwitch, Browser Matriarch-editor or Chonky if your setting is really taken.
Same with the settings for switching Midi clock and/or start/stop on or off.
Thanks for the advice - I’ll have a look. Must be something I’m not doing in the Global settings. The other things have been fixed by new firmware after chatting with Moog service department - they have been brilliant.
