Moog Liberation Technical Info....Wiring For Cable
Howdy fellas…a plea is out. I am desperately seeking the proper wiring schem. for the cable connectors on my moog liberation. Someone had it hard wired in and I’d like to re-do it properly…I can wire it fine but just incase the unit is ever plugged into another power supply, I want the job to be done as stock. Just gotta know which colored wires ( or just which wires ) go to which pins on the connectors of both the power supply and liberation body…or where i can get good schematics which show this info. I realize some of you have liberations and I’m not gonna ask you to pull them apart for my sake …but would ya! …just kidding, but if any of you do happen to know the info, I’d forever be in your debt…if not for me but for my gimpy lib. Cheers HIMMM
It’s amazing what you find using “moog liberation” in google
http://www.sequencer.de/forumsynth/moogschaltplan.html
P4 is the cable connector. Wire colors are liberation body.
P4-1=(+)15v red
P4-2=(-)15v black
P4-3=trigger out white
P4-4=CV out yellow
P4-5=ground green
P4-6=audio out brown
P4-shell=chassis ground
MC you kick arse! I (think) I get the sarcastic edge to the first line of your reply…I know, I know I should be able to look up my own shite but I printed off 3 schem versions and none of them were legible/complete. Soooo I thought I’d go to the best! Anyodd thank you very, very much for your help, it is greatly appreciated. The lib will howl again! Cheers HIMMM
