Moog Labyrinth U Mix 1 LVL not normaled?
The manual says you can have a extra audio signal in the U Mix 1 (or 2) that signal is then normaled tot he mixer and. But when I patch another semi modular synth in the U Mix 1 and turn the knob of the U Mix 1 LVL no sound is heard.
Also with nothing inserted the U Mix 1 LVL knob doesn’t do anything. The manual says it is normaled to the Ring Mod. But when I turn the Ring mod level the U Mix 1 LVL knob isn’t doing anything.
The knob does work if I path the U mix 1+2 out to the VCF in for example. Then I can control how much signal is in the flow. But then I can’t use the M VCO anymore or the normal VCO as that connection is broken.
Is my device faulted or is the knob supposed to do nothing while not patched?
