Hello, I wanted to ask how I connect the moog labyrinth with fl studio in order to play notes in the piono roll from the moog, I only have electron as hardware, that’s via overbridge. I have a motu mk5 interface
This is a pretty general question that might get a lot more response if you were to post it in a place like Gearspace, but let me give you a head start.
The Labyrinth does have a MIDI input, so you’re in luck there. You’ll need to get the correct adapter to convert a normal MIDI cable to the TRS Type A connector. After that it’s a pretty standard affair similar to all MIDI instruments. You’ll just need to run MIDI from your computer’s interface to the Labyrinth and you should be good to go.
Just be sure to get the “Type A” adapter. The “Type B” won’t work.
I have been in similar situation with Logic.
My ESI MIdimate EX was not working, maybe because it is broken?
I ordered a cheap USB to Midi Adapter with indicator LEDs. Then I soldered myself an Adapter from DIN female to TRS mini jack. And now everything works like expected ![]()
