So I am pretty new to this kind of Synthesizer like half modular and I need help to adjust the scales of the labyrinth.
I have been looking into the manual and they are writing something about it but I don’t know how to configure it on the labyrinth.
Any help is appreciated.
Thank you.
meanwhile I found it out.
But this bloody machine doesn’t behave correctly!!!
When I record a pattern there are always notes not in the scale. I hate it and thinking to sell it again
Probably an OS error.
Which OS do you mean?
Synthesizer functions like MIDI or “recording” of something are usually controlled by a microcontroller, and that controller operates with an OS. That there is no “factory reset” or “OS update” function does not mean that there is no controller and no OS inside.
As it has no USB, there is also not the hope that the OS will not be upgradable, right?
The Labyrinth is still usable for me, but not in the way I was hoping when I researched before I bought it.
I mean, with the envelopes it got - it´s more like a drum machine. So if want to have melodic percussion sounds, I need to flex or tune them after I recorded them in Logic Pro.
Not the workflow I was hoping for ![]()
I have the same problem as you and don’t know what to do. Have you solved it yet?
Unfortunately not
