I’ll soon be moving to the UK and would like to take my beloved MG-1 with me. Does anyone have any thoughts on whether it will be safe to use it with a transformer to adapt to the UK-style voltage? Thanks.
Will be fine with a transformer. You will need one that can convert 240 to 110 volts.
Yea, boeing is right. I found the best place for these online is
http://www.voltageconverters.com
It can convert both ways. You usually want a unit rated higher in watts than your instrument. So if your instrument is rated at 20w go with a 50-100w unit.
Hope this helps. I had a similar issue when I imported a UK odyssey and needed a transformer to operate in the US.
