moog 15 - studiomux help please - halfscreen
hi
I am using studiomux and I am able to trigger it in Logic X successfully.
The model 15 app appears in Studiomux as a half sized module surrounded by all the studiomux sliders which makes it unviewable.
I then opened the model 15 alongside the studiomux app in an attempt to use the full screen version but it does not update its settings from the studiomux which is running the model 15 from within it.
I am a bit lost here , any help would be greatly appreciated.
Please could someone tell me how to use the model 15 in full screen on the iPad via studiomux as I’m so near but can’t use it properly as its in half screen surrounded by studiomux’s interface.
thanks justin
just wanted to add I have solved this
ok definative guide to using studiomux
1.DOWNLOAD STUDIOMUX APP
2.DOWNLOAD SERVER FROM STUDIOMUX WEBSITE (GOES ON MACBOOK PRO AS RECIEVER OF IPAD INFO)
3.OPEN STUDIOMUX APP
4.** IMPORTANT OPEN INSTRUMENTS THEN IAA INSTRUMENTS THEN MODEL 15 AUDIOBRIDGE TO THEN CHOOSE SECOND ICON ‘MODEL15’- IGNORE TEH ONE ABOVE IT LABELED MODEL15 AUDIOBRIDGE
and there you have it everything solved. The app will open in full view.
Hope this helps someone who has same situation as me.
